mount flash disk
If by "flash disk" you mean a SSD, there is no difference at all between it and a HDD: they work with the same logic.
But also if you mean a flash drive (a USB stick) it's the same logic. Every devices behave the same way. Usually, you mount a disk (SSD or HDD) as /media/hdd; instead you mount a USB flash drive as /media/usb.
That's all.
