Hi all,
Apologies in advance if I'm posting this in the wrong thread. I've been experiencing an issue with the mount manager in all Black Hole images including the new Open Black Hole image.
The issue is when I set up a network mount for my NAS, a connection to it cannot be established. The icon (looks like a globe) just remains faded, instead of becoming green / blue. Therefore I cannot access my network mount.
I know the setting are correct as I have taken them from a personal back-up from a previous image where the settings did work. I have included the setting below:
<mountmanager>
<cifs>
<mount>
<active>True</active>
<hdd_replacement>False</hdd_replacement>
<ip>192.168.137.3</ip>
<sharename>DanielsServer</sharename>
<sharedir>c</sharedir>
<options>rw</options>
<username>admin</username>
<password>***********</password>
</mount>
</cifs>
</mountmanager>
The above settings worked fine for me up as far as Black Hole 2.1.0.1. Then I tried installing 2.1.1 and I discovered the issue, the network mount simply just would not mount with the exact same settings. I tried several versions after that as well and the same issue was present in all of them. I thought that the issue may have been resolved in the latest Open Black Hole image but unfortunately it was not.
Can anyone offer me any advice on how to troubleshoot this? Is there anyway of accessing a log file to see if there is anything? The receiver is not green screening so there is no crash report to look at. Or am I just destined to be stuck on 2.1.0.1 forever!
Many thanks,
Daniel
<mountmanager>
<cifs>
<mount>
</mount>
</cifs>
</mountmanager>
Many thanks,
Daniel
