Mount manager vu solo 2
Icemen
Hi should I have anything showing in my mount manager tab. I got a 1TB internal hdd installed. I have re flashed latest image. You can add to the mount manager but it asks for a share name and ip address. What's all that about. Basically I want to know if my hdd has been installed correctly and is ready for use
Hi
Go into menu - hard drive and initialise the hard drive and make sure it's set to running, then go into mountpoints and set the hdd as /media/hdd
Thank sid what shall I name the share point and what ip address shall I input my box one? for when I go into mount manager after I initialise the hard drive
