Mounting usb on boot
danska
hi to all ,
is there any way to mount usb pendrive when booting from deep standby ?
cause it's not detected by the box when booting , so i have to unplug the usb pendrive then plug it again go to device manager map it and restart .i can avoid restart by telnet mount or simple script but still have to unplug and plug..
so is it possible to let the box detect the attached usb on boot and mount it ?
Buy cheap USB stick 2Gb,
because your usb stick is not good for VU box.
I have four USB sticks and all but one are working perfectly.
In most cases an expensive USB sticks working poor such as kingstone e.t.c
thanks Matrix10 , i have a 8 Gb kingstone it's working very good
except booting from deep standby or power on from rear button ,
so i will try an other usb and see
