Movie cutting plugin not working
misterdeff
hi guys i have installed Blackhole 1.7.3 in my VU+duo with a 2 terabyte harddisk everything is working fine, the only problem is im trying to install movie cut or anyother plugin to cut and edit my recordings , when i install any of them it reboots then i can't find it anywhere, could you please guide me or advice me any plugin for that.
I'm not sure abt BH 1.7.3
because i have now BH1.7.4 in ULTIMO box and there is one.
Normally is located in each image.
Are you sure you have press Menu button when you are in the movieplayer list.
No its not there, i have installed the image downloaded from this forum.
Maybe you can check again. I have BH 1.73 image downloaded from this Forum and have it.
Press the button next to Menu, the button between Menu and Audio. Then you'll have the Recorded Files. Then press Menu, and you'll have Movielist menu:
delete
Cutlist editor...
alphabetic sort
list style default
list syle compact with description
list style compact
list style single line
show extended description
