Moving from DM800
packetstormer
I am just about to purchase a Vu+ (not sure if Duo or Solo yet) but I am wondering if it will accept an Enimga2 backup from my Dreambox 800 and load the settings onto it. I am specifically worried about my motor settings. Some of the sats are using USALS but some are using positioner settings. As it tooks my weeks to setup the DM for the motor I just couldn't go through all that again!
Does anyone know (or have you moved yourself) if creating a backup on the DM and restoring it on the Vu+ will work?
My first E2 box was the 800HD and although it was a great box in it's day things have moved on.
The Vu Duo is a great box and you will not be disappointed.
As for swapping over the configs and settings, in theory they will work but due to the duo having twin tuners and the fact that drivers and improvements within the image have taken place you may find that it is not a straight forward transition.
I know it can be an awful task to swap everything but trust me, you will feel it was worth it.
