I have DM800HD with 22 Sat defined on motorized dish. I want to buy the VU+ Solo 4K.
is there a fast way to transfer my Sat def. to the new box?
I am using dreamset to manage my channels. can I use it on VU+ to transfer channel list ?
Are you using Usals, or Diseqc 1.2, to drive your motor?
Usals is easy to set up, Diseqc 1.2 takes a few minutes, I have to use Diseqc 1.2 as I am using a 36v motor and a V-Box II.
Should only take a few minutes, after loading your image, to set everything up, using the wizard, including the tuners, and then load your channel list.
All you need is your new receivers IP address.
