MTISF tuner
Yes it seems so ... thanks.
I purchased one of these MTSIF ... it is strange that the existing information only indicates that it is a DVB-T2 tuner and not DVB-C / T / T2 ... the manufacturer (Vu +) on its product page does not go beyond T2, the product packaging itself, the information that exists in stores ...
Dual means in itself "double standard", DVB-T/T2 and DVB-C, always.
Twin means "two independent tuners" by one physical device.
Hi
I want to know anybody used this tuner for cable?
I’m looking to buy for cable , I have FBC tuner but problem to setup autobouqetmaker uk VM black hole Image
Thank you
Maybe it has that (dual) meaning ... maybe. What does the T2 indication do there? Why did you choose this one and not C?
The logic is like this in the USB Tuner Turbo, where it indicates what it supports ... or not?
What's the problem ?
You can use the MTSIF tuner as a T / T2 or as a cable tuner.
There is no problem ... who can have it will be the manufacturer who, by not explicitly indicating that this device meets both standards, may not sell it as I would expect ... I knew it by chance and then I bought it.
If I remember correctly
The first time MTSIF Tuner came out he was just working on T / T2
VU+ made later new drivers for cable TV.
http://code.vuplus.com/gitweb/?p=vu...ff;h=a0dc70219493e20a8aed6a5c7887af576fc37226
I also had the idea that it only worked in T / T2 ... and as I say, the indication that exists everywhere is this (ab-com just to give an example among all) ... all stores put it on sale as if it were only for T / T2 ...
It is clear that the information about this upgrade to the tuner was not disclosed in the store chain ...
I'll pass the information to a store here in the country ...
Hi Friends , Can I add dvbs2 x ms tuner ti vu solo 4 k , Pls confirm anyone. Thx
Ok thx , for such a quick reply for my query , I am very satisfied with the machine , thought of adding s2x tuner as now multistream is expanding its wings gradually
You are :offtopic:here ;)
The thread is about MTISF tuner and not about S2-X tuners that supports MultiStream.
