MultiMediathek 3.0 on VU+DUO
remek30
I wanted to ask whether now VU + DUO will not be able to use the plug-Multimediathek 3.0? Earlier versions do not work and after the upgrade to version 3.0 a message pops up: Geniune dreambox validation failed! Verify your Dreambox authenticiti by running the genuine dreambox plugin! .
Does this mean that the VU + no longer can use this plugin if there is a possibility?
Same problem here.
VU+ Solo MultiMediathek 3.0
"Genuine dreambox validation failed!
Verify your Dreambox authenticity by running the genuine dreambox plugin! "
Is this a bug or we must remove plugin?
Same here on ver 3.1 not a genuine dreambox..... :(
tried go back to ver 2.9 but it wouldnt work either... :(
so have to wait for a fix.. :)
Try this plug-in... a little help , till a fix comes up!
Tested & works w/BH!
Same problem here.
It seems that the author of this plug wants it to be run only on Dreambox.
MultiMediathek error message (sorry no supported videos found here)
hi
how can solve this .
when hit save on HDD or Direct Play or Cahed Play
this message Message Popup
If this MultiMediathek version is not the original from the MultiMediathek author .
I like to ask you to remove or to contact one of the administrators to remove them.
We do not want to have plugins that are not in conformity with the wishes of the author.
Thanks MX
Installed new MultiMediathek 3.2 version, and work great, but i don't understand which key to insert in Option Settings Menu to add "Genuine-Key to pass Genuine Dreambox verification process"
Any idea?
Regards
Now i got message pops up: Geniune dreambox validation failed!
Any key to by pass geniune validation process?
Wrong info. ;)
Officially the author don't permit the usage of the plugin on boxes differents from Dreamboxes.
If some people hack the plugin these people make at his own risk but without author permission the modded plugin cannot be posted on this Board.
In fact, it tied DM'ye Genuine against clones produced.
However Vuplus, Azbox, we caught the ball almost as Xtrend users, he must be a way that we're not clones.
Then we found a middle way, Paypal system, the amount invested in return for € 5 or your e-mail serial-number to come and open the plugin settings to use when you enter serial number.
Yours ...
I do not want here advertisement for paid plugins.
Those who once proclaimed open source now proclaim Paypal system.
We do not need these plugins on the forum, even when they are made ​​of gold.
That is his right to give or not plugin for other boxes and images.
But we do not advertise Paypal system plugins.
So posts which mention the money from users for plugins are not allowed here,
nor is it allowed discussion about them.
