multiquick button plugin on upload doesnot work correctly, after install most of the keys don't work.
The only way to uninstall it (due to buttons not working) is first to disable it to start via menu/plugins than uninstall.
multiquick button plugin on upload doesnot work correctly, after install most of the **** don't work.
but is very usefull the possibility of customize them (specially the "long pressed" ones!)!
the only exception is the "blu key", that i think is a must for using the BH images, that is overwritten by the standard installation of the plugin: the "patched" version in the link Zupy shown 2 post above is perfect for Black Hole!!!!
Green and blue are important for BH images, adapted plugin do not touch them in start so it can be used on BH.
This plugin can change function most of the buttons so if you want - for me it is excellent (fox example I move boring timeshift and put epg and so on..)
