MultiQuickButton
<map context="InfobarShowHideActions">
<key id="KEY_OK" mapto="toggleShow" flags="m" />
<key id="KEY_ENTER" mapto="toggleShow" flags="m" />
<key id="KEY_EXIT" mapto="hide" flags="m" />
<key id="KEY_ESC" mapto="hide" flags="m" />
thanks paper i just did that but what about if i want to control it x2 ok to show extra info bar and one klick to show the channel list?
Hi, I have never been able to use x2 OK.... some times ago I tried with some version of MQB (that was not for BH image) with the chance to use x2 OK , but there were some problem using it....I don'remember the version and where I found it.
If You can find solution tell me.... :-)
p.s.
To show extra info bar, if I understand what is the goal, simply check "Disable light skin on zap" in OSD option: in that way, pressing ESC (if confiured with "toggleshow") , you can see the normal and extra bar
g.
