Mutiboot sort
Tjey are sorted by install date but if you change name of them i think they will be sorted after the new date
So change name in revers order and you get the one with oldest date at the top
Probably changing the name changes only the "Modified" date, not the Creation Date.
You should try to change this.
upload images
Again: renaming is not enough to change the creation date! You need a specific FTP software! But not all of them are able to change such attributes and we don't even know which O.S. are you using: on such basis, how can we tell you how to change attributes? Look over the Internet about software able to do that.
I am using blackhole 3.0.9.e as omb
And Windows 7 as os
So you need a software for Windows to change these attributes connecting via FTP. But I don't use this sort of OS. Surely, Filezilla is not able to do that. Search over the Internet.
We need to study, sometimes, to learn ;) Especially if the "problem" is not really a problem.
