MX HD1
Matrix10
:dance: :fie:
niglou
BH Lover
Hello Master,
I know you are using coloured boxes (png) of different sizes which are displayed into the different menus. I guess it's a lot of work to change all of them when you want new colour.
I was wandering what would give the fact to use a white box with 3d effect, and then apply a coloured label on it, provided you can apply a blend filter to keep that label semi-transparent. Of course we can forget the rounded extremities, but does not look bad (see Timer entry picture).
In that case, it would be easy to change colours, just with few lines into skin.xml, and why not through a menu.
