MX Lacroma
Matrix10
Continued HQ10 series of skins
MX Lacroma
two versions on the Black Hole Image Server
(green button >> Yellow>>addons download manager>>Black Hole image skins)
MX_Lacroma
MX_Lacroma V2
This version (V2) uses about 10% less color saturation for menu panels icons.
The colors are less aggressive.
skin format 1920 x 1080
picon format 220x132
AlexWilMac
Moderator
When you download and install Lacroma V2, it doesn't appear among the skins.
In Lacroma, entering the recording list, the scrollbar hides the seconds' duration of recordings.
Matrix10
Both skins have the same name,
The installation overwrites another .
"the scrollbar hides the seconds' duration of recordings"
Can you make screanshot ?
rachidito
MX Lacroma
MX_Lacroma
MX_Lacroma V2
incroyable
AlexWilMac
Moderator
Sorry for my late reply but I couldn't before. Here it is
AlexWilMac
Moderator
I have some fonts, yes, but not for the skin (only for L4L). And this one in the skin is the standard, as far as I know.
inpoggio
Very well done. I use it and appreciate a lot. I run a bh3.0.2.j and had a problem with MX HQ10xc. The menubar exceed the screen. I have a fullHD tv and setup on 1080p, and no trouble with any of all your other skins. It happen only with 10XC.
Matrix10
Yet it is up to the television or setup.
You do not have the whole picture on the screen .
You have to setup TV ( if it is possible ) or use in BH image UI position setup plugin to tune picture size/position.
Nitemare
Hi Matrix10 ...
I see you are updating skins for BH 3.0.4 and OBH 1.0 recently ... is ther any plans to do same for Lacroma for OBH 1.0 ??
Thanks for great skins and work!! :)
Matrix10
Hi Matrix10 ...
Im sorry
I think not for OBH,
the image is constantly changing ,
and then I do not have the time or the will to make again graphics and coding.
