MX_Graphite_HQ_P
some info that some will not find.
pressed left or right >> Menu >> you can setup and have Single EPG info in OSD
If you are using EMC
Press the button Menu when you are in the list
setup in EMC Setup >> List box is able skin >>yes
You will have bigger letters in the movie list.
In this image and skins you have so many options , try them out .
A small update to the skin on OBH server.
Deleted unnecessary skinV2.xml backup file
Now the skin is half Mb smaller.
Delete/uninstall and instal skin again.
