my epg t usb tick how to ?
jjp2701
i am trying to get my epg to go to my usb stick but dont know how to, does anyone have a step by step guide please, i am running the latest blackhole image, and got my usb stick, in the usb slot at the back of the box, the first slot from the top of the box,
and is it possible to record from my usb stick ?
First of all you have to mount your usb with blue panel, device manager.
Then blue button, red button(epg panel), red again (global settings), modify path to save epg.
But it is strongly raccomanded that you don't change path for hdd, as epg is tructured to work well with that path.
It is useless to move epg from hdd, as epg is in flash anyway.
