Solo2 My Solo2 goes to coma for a few days !
erisdoros
lately after I upgrade my solo2 software, it has a new problem. I can get the services perfect half of the times. from one point and I dont know exactly when, my solo2 goes to coma and doesn't show the servies. when I leave it ON in one of the servies for one or tow days, it weaks up and start working. I don't know if this is a hardware or software problem. Can anybody help me in this regrad ?
BH: 3.0.3.H Kernel: 3.13.5 DVB: 20161228r0 Build: 2017-03-27 mastter
Hi mcc / I did and did not work. I have the "enigma2_crash log" but can't copy it here ! Does it help?
Crash is created when is something in image no work good.
If im good understend you have problem with install new image on box?
You try last BH 3.0.4 or OBH image ?
You try install from other usb ?
Hi bogdanm,
I am not sure if the problem is with installing the new image or it is from hardware. This is my question !
I tried BH 3.0.3 and OBH image and I'll try BH 3.0.4 as you suggested.
What you mean by "other usb" other flash or other drive?
I have HDD installed, is it possible the information on HDD cause this problem?
Thanks a lot
Hi bogdanm,
Thanks a lot
- no all usb work good with boxes best work old 1-2 GB usb drive and if usb is no good recognized is hard install image on box.
- somethimes HDD doing problem; if you can try hdd remove from box and next install image.
