My solo2 with BH 1.7.9-3 didn't start when i reboot
HCR
Hi.
My solo2 didn't start when i reboot after my first installation of the image. The box works fine the first time when i install the image but if i break the mainswitch and try to start it again it will stuck on starting.. there's no problem to start from standby.
i hope anyone can help me to solve this problem.
so, can you write down exactly what you're doing when installing new image? Why are you switching off your box?
Have you tried to install original image?
Hi ! I had the same problem! On another forum I found a solution. go to BLACK HOLE Shutdown and HARD Resed . After that will be all right.
