Mark anthony thomas
New flash and now I have NAR talking on every channel. I press audio button to and click down off NAR but if I leave the channel then return to it the NAR comes back on. Thanks
yes black hole but I don't understand cfg. What is it?You used OBH ?
You no setup in cfg prefered language to NAR ?
NewGo to the Preferences among Audio settings and disable the NAR as preferred audio track (although I'm not at home and I can't remember exactly the item needed to do that).
Anyway, the more you browse your system the more you learn it.
New
I have tried to disable the NAR in audio settings but as soon as I change channel the NAR comes back on
