NAS and recordings
Blaster
Hi. I have an QNap NAS I would like to use as an extra place to save and play my recordings. But I also wan't to use the internal hdd in the VU+ Duo2. And switch between them (switch which one to record to or to play from). Is it possible? And how do I do that? I haven't manage to connect to my NAS properly either. The NAS has a shared folder (Full access) that I wan't the VU+ Duo2 to use. How do I setup this?
yes, you can set the " record path" from the menu -> setup - system
you need to use samba to connect linux to a nas.
Yey! Figured it out. I was configuring the NAS connection, but I had to click OK on the NAS so the shared folders came visible, and then configure the shared folder. Now it's working :-)
The only thing I wish could be better is the filename of recordings. They're not showing episodes. Just the name of the program. It's very rare number of episodes are saved in the filename. So it's kind of tricky to find back to a spesific recording. Any solution for this? This happens both on NAS and local disc.
Using BH 2.17. VU+ DUO2.
No one? I wonder if it's possible to config so that the filename of recordings could be a bit more detailed? With episodes for example?
