Do you have mounted CIFS or NFS?
I can access to the files in the NAS from Vu+duo2... But when it comes to record... Nothing happens
NFS. Do you have writting permissions?
Check your access rightsthat's the problem, i can't access the files inside the HDD with media player
Can you spot the NAS IP from network settings?it's not an access problem because right i have two other vu+ solo (with older blackhole 1.6 and 1.7) and both have no problem mounting the HDD and using media player to access the file.
before upgrading to 2.1.3 and 2.1.4 i used to have 2.0.2 and it was working perfectly.
