Need help buying Vu+
BadBlake
I'm thinking about what to buy, and I need help deciding between the two I have picked out.
The Vu+Uno 4k or the Vu+ Duo2.
I don't really care about the 4k features so that is not a deciding factor here. I'm interested in the following features:
stability
good hardware
twin tuners
able to handle kodi /IPTV well
good streaming capabliity (I want to stream from this unit to my Vu+ Uno and Vu+ Zero,which is on the same lan)
I think maybe the Duo 2 might be the best choice here -am I wrong?
Would love some help deciding which one to buy.
stability
good hardware
twin tuners
Not Duo2 and Uno4K.
Give a try to Uno4K SE, you will not be disapointed.
I have deployed
Vu+Solo4K ( Home server Station)
Tuner FBC A - 23,5° 19,2° 13° 0,8°
Tuner FBC B- 23,5° 19,2° 13° 0,8°
Extended Tuner DVB-S/S2 (TWIN TUNER) - rotating Disecq 100 cm dish
Openatv 6.1
Home Client 1 - Vu+ Zero
Home Client 2 - Vu+ Zero
On wlan cable with plugin Remote channel stream converter
For outdoor access...Smartphones etc Vu+APP
I don't need 4k. I just want some help choosing between Duo 2 and Uno 4k. Which of the two would you choose??
@BadBlake ==> +40€
For price and performance VU+Uno4K SE (8 tuner) = 270 €
VU+DUO2, very good, but old already ("obsolete") and very expensive, 2 tuner SAT = +400 €
I would buy it with 4 tuner better, more expensive.
PS: I have 3 VU+DUO2, 2 bought second-hand, very cheap, also a VU+Ultimo4K.
Por precio y prestaciones VU+Uno4K SE (8 tuner) =270€
VU+DUO2, muy bueno, pero viejo ya ("obsoleto") y muy caro, 2 tuner SAT = +400€
Lo compraria con 4 tuner mejor, mas caro.
PD:Tengo 3 VU+DUO2, 2 comprados de segunda mano, muy baratos, tambien un VU+Ultimo4K.
