Need help setting up tuners in ultimo please
IVAN3377
i have set it up as tuner a single simple with a cable coming direct from the sat
set up tuner b equal to a with a cable direct from another sat pointing in the same direction as sat a
dvb t is to a digi aerial which works fine can record up to 5 or 6 channels at the same time
My problem is that on tuner a and tuner b i can only record 2 channels and when i switch to another NO FREE TUNER need help please what have i done wrong i have tried different tuner configs but end up witch same results :confused:
