Need help to fine tune motor
Fred Cole
Hi There, I have a VU plus solo with a motorised dish and it works on USALS. I live in a very windy area. Sometimes the signal strength goes down considerably and I have to increase the longitude by one to get the signal strength back. Even when the signal is at its highest (87%) , certain weak channels struggle to be viewed. I need to find a way to fine tune the satellite position to increase the signal strength.
Maybe I could disable USALS and save the main satellites (13E 19.2E 28,2E etc) manually so that when the signal is a bit weak, I can simply fine tune the dish position? But I do not know how to do this, can anyone tell me how?
When I had a dreambox, I used to uncheck "GOTOXX"
Thanks for reading
