Need help with back up system
vamas
I am presently running my system via Avalon.
Do i need to go back to BH to be able to load the new BH image?
Also i have tried to make a back up but system now does not read my usb. When i try to do a personal backup it tell me that the usb is not mapped but when a tried to do a full back up then usb is read and i can go ahead with doing the back up. Does this back up saves my motor settings etc?
thanks for some advise soonest as i do not fancy having to set up the whole motor system again.
thanks in advance for your help - vamas
@ mito
thanks for your quick answer. It seems that to upgrade to this new Bh then we have to do all from scratch, hope it will be worth the trouble.
@ mito
U can save Bouquet/channel settings using software-manager ,,,,,Save them on /HDD and U can use them again!
And yes the upgrade is worth it,,,there are so many features added to BH 2.0 oe2.0!
Have fun with BHImages!
