Netgear Driver
KingNaples
Hi All,
are available somewhere the driver for VU+ Zero of Netgear WNDA3100 V2 or WNA3100 ?
Thanks for any Help!
Hi All,
v1 should be already supported by carl9170 driver
v2 not supported. No driver avaiable for Broadcom chipset used
v3 can be supported. Driver exists but never tested before.
Hi,
many thanks for the information, I have also one WNA3100 are the drivers available?
Also could you suggest an high perfomance adapter to be used?
Many thanks again for the continious effor You give All
Hi,
Depends on your WNA3100 revision according to my previous post.
