Netgear wnda3100 on solo2?
I'm using a wnda3100 V2. Now I've tried with a cisco linksys wusb600n v2 and it doesnt' work. I will buy on other one. Thanks
The Linksys wusb600n v2 seems uses a Ralink RT3572 chipset (not included into BH images - but avaiable from manufacturer). I will try to compile them ASAP.
I've discovered there is an updated driver ;)
okay, thank you
I've built the RT3572 for Vu+ boxes.
Please install the ones corresponding to your box and report if works or not. I've tested only the installation phase and not the working because I haven't a supported device.
