netspeed or netbrowser ?
hilde
Is there a netspeed and netbrowser plugin ?
-> and a howto " howto mount CIFS / NFS (permanent) "?
How do i change in successfully mounted CIFS rsize and wsize
BH144 Vu+solo
The black Hole mount wizard (twice blue) does not help realy for optimization rsize,wsize and "try on error" ....
Any changes in BH145? (Never change a running system
Solved
According to http://wiki.blue-panel.com/index.php/Auto_Mounter is in /etc an "auto.hotplug".
There you can edit your Mounts - They will appear under /autofs (in my BH144 Vu+solo)
Eg see link and attached:
* -fstype=auto,rw,sync :/dev/&
AAF-ufs912 -fstype=nfs,rw,soft,udp,nolock,rsize=49152,wsize=8192 192.168.0.21:/media/hdd
PC -fstype=cifs,rw,soft,rsize=65536,wsize=32768,user=guest ://192.168.0.2/Public
