Hello,
Just upgraded from 2.1.5 to 2.1.7. Great image as usual !
Thanks for your work.
Still, I have one issue I don't understand : I have a NAS (Syno) with a NFS Share mounted. Everything works flawlessly but every time I restart the STB, I have to re-connect to the share (via Setup>System>Network ... mount management and re-select the mount (a little red cross is present on the share), resaving the parameters and then it is connected and everything is fine.
Also, I don't see any option to configure my recording paths anymore. Is this related ?
Do you have any idea ? Am i doing something wrong with my share ? (i Had the same issue on 2.1.5 but I could see "recording path" option).
Any help would be greatly appreciated.
Regs,
Legau
Regs,
Legau
