Network problem
Dear all,
My Vu+Duo works fine under BH 1.7.2. My wireless network, via USB wifi, is fine but as I have a poor signal quality I decide to switch to wired network. My connexion cable works correctly on my laptop but when I configure my Vu+Duo to use LAN interface the test doesn't pass the DNS even if I enter its IP address manually.
I will be thankful for your kind help
You have make reboot before test and after IP change ??
after resetting box got network going again........still not happy with hdd crashes and will have a word with vendor............box only a few months old
