New Box Vu+ Zero
Search40
Cheap nice little box, i have Vu+ Solo2, and Vu+ Solo se, below are the Specification, hopefully images will be ready for this box is well:
Affordable DVB-S2 HD Zapper
There was one goal in developing ZERO from the beginning. Let’s make something more affordable to please more Vu+ fans. As the name suggests, the end user price of ZERO is remarkably competitive while maintaining the performance and philosophy of Vu+ products. Zero is the most affordable DVB-S2 HD Zapper of Vu+ ever.
Powerful Features
It was certainly a challenging task to increase the affordability while not losing the performance that Vu+ pursues. So, ZERO comes with a 2000 DMIPS CPU powerful enough to support all demanding multimedia functions. Despite of its compact and slim design, all important connectors are nicely equipped as below:
Slim & Elegant Design
ZERO characterizes the design philosophy of Vu+. Its elegant external design is stunningly standing out among those monotonous and tasteless set top boxes in the market. ZERO’s beauty deserves to be placed right next to your TV. ZERO comes in black and white.
An Ideal Solution as a 2nd Vu+ Set Top Box
ZERO is a smart choice for those using HDD integrated Vu+ models like SOLO2 and DUO2. Let’s assume you use ZERO in your room. Once connected in your home network, you can play multimedia contents stored in DUO2 or SOLO2 in the living room. ZERO is definitely the most ideal solution for your second set top box.
Technical Specification
  • CPU (MIPS) 742MHz
  • 512MB Ram
  • 256MB Flash (NAND)
  • 1x DVB-S2 tuner
  • 1x Smart Card
  • 2x USB
  • 1x RS232
  • 1x LAN (100Mbit)
  • 1x HDMI
  • 1x S/PDIF
  • 1x Composite Video
  • 1x Analog Audio (Stereo Jack)
  • PiP (Picture in Picture)
  • HDTV
  • LED Status Display
I just so that this box been tested, and have image o ready by Black Hole, sorry did not see that before, never mind getting old, LOL !!!!!
