327521609
Good morning VU Community,
I have purchased a VU + Duo, I am moving over from Sly TV this month but I need some advice please.
I have a magic eye in my bedroom and the Sly box is in the living room. When I install the VU Duo I understand that the Triax Tri Link kit (RF Modulator) will do the same job? I am wanting a kit but with a HDMI option cabled not wireless what would my best option be?
Also I don’t have any internet in my living room so would need a wifi adapter for the VU + Duo. I do have a Vonets VAP11G WIFI Bridge which was used for my Sly Box. Is this fine to use or would you recommend another device?
I wish to install a SATA hard disk into the VU + Duo. But cannot decide on either 250gb / 500gb / 1TB, Does anyone know how many hours of video the VU + Duo could record on the hard disks I have mentioned?
I wish to install the Black Hole image as you guys recommend it, is there a idiots guide to do this as I don’t want to BRICK my system straight away.
Also please could you recommend a 7 day EPG with is the closest to Sly / and a series record plug-in if available?
Thank you in advance
Tom
Tom
