HI there,
I'm sorry to bother but I definitely need help because I'm on the verge of loosing my sanity. I've been having nightmares of smoky zombies chasing me with VU+ DOU2 glued under heir armpits. Please help me, I've never owned a VU+ before but everybody I asked convinced me to go for it. After seeing the glowing reviews I couldn't help but to buy it and I have no regrets.
So two weeks ago I bought VU+DUO 2 Full HD 1080p 1x DUAL DVB-S2 & DVB-T2 & 2 TB HDD. I've been trying to set it up with Alsat Superior Dark Motor which I bought in the same day. In addition, I bought a LNB Inverto Unicable IDLB-QUDL42-UNI2L-1PP.
As instructed, I spent two weeks scouring all the threads and following all the steps but so far I haven't managed to get a fix. I'm only managing to get one satellite each time. Everytime I try to go others, the motor doesn't respond. I believe that the problem stems from Tuners configuration or and LNB. Basically, would like to get a fix just for satellites: 30 Hispasat, 7 Eutelsat, 13 Hot Bird, 19 Astra1L and 28.2 Astra.
Could someone kindly and patiently explain which steps I should take PLEASE? Starting from how many cable I need to connect to Unicable LNB (there are 3 ports LNB1, LNB2, and the third (golden) look like the loop symbol), to how to connect them at the back of DOU2 and the Tuners configuration. What's more, on latitude and longitude I get these positions from Dishpointer: Latitude 51.0390 and Longitude -0.07463. How do I insert these values onto sat positioner?
Please help this dazed rookie.
Many thanks in advance
Timoh
DU0 2 flashed with BH 2.1.6.1
Timoh
