NEWBIE IN NEED OF HELP!!
bon1demarco
Hi
I was wandering if someone could help me please?
I preformed an update on my vu+solo2 and when it was finished my boxes screen has gone black,
when i turned the box off and on it just went to a black screen again.
I have looked at a few threads and downloaded files to flash the box as was directed to do on forums,
but my box would not update it just preformed the same as if i had no usb in it.
i have other files from work on it could this be a factor.
Does the usb need to be clean.
All help would be very much appreciated
Kind Regards
bon1demarco
Instructions for updating the image of Vu + Solo² via USB
Image on PC save (USB version)
unpack file
USB stick with the FAT file system or format FAT32
/ Create folder vuplus / Solo2 on the stick
Copy the 5 files in the directory / vuplus / Solo2 to the stick
Off VU + STB
remove all USB devices from the box
USB Stick infect
VU + STB Switch
Wait for the message update please press "Power"
Press "Power" button on the front of Solo²
waiting for message "Finished, Removing USB"
Disconnect USB stick from the box
Off VU + STB and restart
Try this. Take the right Image for your Solo2
Pyromon
Hi
Kind Regards
bon1demarco
Usually this happen on clone boxes...... have you a genuine one?
unpack file
Off VU + STB
USB Stick infect
VU + STB Switch
Pyromon
Hi thank you for your advice can y
Your first post states that you have a VU+ Solo 2, this post mentions a VU+ Solo, both are different receivers, and require an image, specific for your VU+ model.
Please check which VU+ model you have and download the correct image.
Ya sorry it is a vu+solo2 have tried a few downloads and any time i put the usb in the box will not read the update i am using
a 8gb usb does it have to be 32gb
No it doesn't.The sticks you are using are quite big just for flashing an image.I use Kingston 4gb but I have used larger ones in the past.Try a smaller stick and when you find one that works just keep that one for flashing.
will give it ago robo.. think its the box its just not reading the info off usb.
