I would like the DUO2 Image File
nfi size
Hi MickMost are basic, Signal Quality/Strength readings, Audio, Dolby Digital. Videooutput, 16:9, etc.....
If you press it twice you get mor informatio, the letters indicate any encryption standard, the subscription channels might be using, e.g. N = Nagravision, C = Conax, etc.. satellite, channel frequency, and other information.
What FTA, Free To Air, HD channels can't you view, and on which satellites? They mioght have changed frequency, or PIDS, and might just need scanning in again.
Hi Mick
Thanks for reply. Let me check out the channels and I'll get back.
http://www.lyngsat.com/packages/Sky-UK.html
http://www.lyngsat.com/Astra-2E-2F-2G.html
