NFS issue since upgrade to 3.0.2 (from 2.1.7)
GSp
Hello,
since the upgrade, I cannot mount anymore my vuduo2 folder via NFS, as I used to do it on 2.1.7
the (same) NFS command comes back with the following error on the client side:
pmap_getmaps rpc problem: RPC: Unable to receive; errno = Connection reset by peer
mount: RPC: Remote system error - Connection refused
Any ideas ?
Thanks,
GS
P.S. I off course checked that NFS is running on the vuduo2 ...
NFS still does not work (running last 3 version) but now with this error message:
mount.nfs: requested NFS version or transport protocol is not supported
??? any ideas ?
