I am trying to share my internal hdd to my other box with NFS. Other images I have run had etc/exports but cant find it in BH. I have activated NFS in the menu but when i try to access it from the other box it dosnt work... Is there something i missing?
When i type mount -t nfs //192.168.1.6:/media/hdd /media/hdd i only get: Mounting nfs on /192.168.1.6:/media/hdd failed: No such file or directory, on my other box
I am unable to connect to the shared hdd from an itgate enigma1 box and from a dm7025 box.
If I try to list shared nfs folders on the solo2 box with the command
showmount -e 192.168.4.100
from an linux machine nothing is listed. If I try the same command on my dm7025 box the hdd share is displayed.
If I manually run the script nfs_server_script.sh from bash on my solo2 box I can se on the screen that exports file is read by the script.
Is there some kind of firewall in the image which is blocking the nfs-server? Or is there something else which is wrong? Can someone tell me how to share my hdd in Black Hole with nfs.
I have similar issue, can't mount NFS share. I press:
Blue / blue / Network Browse & Mountpoints / LAN connections... There I see my server and shared NFS disk. Then I press OK
There I see Mounts editor:
Active - enable
Local share name - ServerName
Mount type - NFS share
Server IP - 192.168.0.2
Server share - /Disk
use as HDD replacement - yes
Mount options rw,nolock,tcp
Then I press OK. Tuner starts to mout. Then I get:
"Your network mount has been updated. "
But nothing changes, no mount appears. If I mount it on PC that NFS share wokrs very well. On Black hole - does not work. No idea what happened. When I installed fresh image 2.0.8 - it worked before.
Hi,
I too am experiencing an NFS share issu under Blackhole for my VuDuo.
I am trying to export an externally connected eSATA HDD as an NFS share for my VuDuo running Blackhole 3.9.6 (May 2015).
I have locally mounted this as /media/exthdd while my internal HDD is mounted as /media/hdd
I cannot find the /etc/exports file which would need to be edited to allow this to happen.
I have tried to create it by using the touch /etc/exports command but this has not helped.
NFS server is enabled of course and even with this I cannot even conect to the </media/hdd> NFS share which is supposed to work "out of the box".
I see that ViX images have kept the /etc/exports file but the Blackhole team appears to have removed it from the build...? Any reasons ?
If someone has a work around to allow full NFS share flexibility (ext hdd share /int hdd share ...no security within LAN etc...) please let me know.
I can't share my hdd from Solo4k running black hole over nfs protocol, I try to mount in other enigma2 boxes but it doesn't actually mount, (it sows mounted if I choose autos but I can't actually access it) I installed VTi on my solo4k and then hdd mounted fine...
