No channel Found with USB Tuner DVBT
semtex57
Hello I'm running Blackhole 3.0.2.E with an USB Tuner Cinergy Hybrid T USB XS FR. The tuner is found, set up but doesn't find any channel.
I was running this tuner in an older version of BH (2) without any problem ! is there anything additional to install ?
I have run the Debug script and found something weird about errors loading firmware ?
But I've joigned the complete file as attachement
Thanks in advance
Sem
em28xx: New device TerraTec Electronic GmbH Cinergy Hybrid T USB XS FR @ 480 Mbps (0ccd:004c, interface 0, class 0)
em28xx: Video interface 0 found: isoc
em28xx: DVB interface 0 found: isoc
em28xx: chip ID is em2882/3
em2882/3 #0: EEPROM ID = 1a eb 67 95, EEPROM hash = 0xfea8f21d
em2882/3 #0: EEPROM info:
em2882/3 #0: I2S audio, 3 sample rates
em2882/3 #0: 500mA max power
em2882/3 #0: Table at offset 0x06, strings=0x386a, 0x34a2, 0x0000
em2882/3 #0: Identified as Terratec Hybrid XS Secam (card=51)
em2882/3 #0: analog set to isoc mode.
em2882/3 #0: dvb set to isoc mode.
em28xx audio device (0ccd:004c): interface 1, class 1
em28xx audio device (0ccd:004c): interface 2, class 1
usbcore: registered new interface driver em28xx
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
b2d1467ad0461049c0de8f82f514447b0b8f016b tryfix v4l2_ctrl_check duplicate symbol #2
64955823cf3bd80743f1f3a5f7d50bd599d8affc tryfix v4l2_ctrl_check duplicate symbol - modify header
e8812dab0d410e2694451a73b421df6fd82b3b07 Merge branch 'bh-master_20140924_bh_dvb_usb_v2' of git.blackhole-community.net:repos/bh/vuplus_kernel into bh-master_20140924_bh_dvb_usb_v2
em2882/3 #0: Binding DVB extension
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
xc2028 0-0061: creating new instance
xc2028 0-0061: type set to XCeive xc2028/xc3028 tuner
em2882/3 #0: em2882/3 #0/2: xc3028 attached
DVB: registering new adapter (em2882/3 #0)
usb 1-1: DVB: registering adapter 1 frontend 0 (Zarlink ZL10353 DVB-T)...
em2882/3 #0: DVB extension successfully initialized
em28xx: Registered (Em28xx dvb Extension) extension
usb 1-1: Direct firmware load failed with error -2
usb 1-1: Falling back to user helper
xc2028 0-0061: Could not load firmware xc3028-v27.fw.
Thanks in advance
Sem
Use it with care.
There is a missing file: xc3028-v27.fw
Must be downloaded manually, place it into /lib/firmware and reboot your box
I was finding parralel the solution by installing the firmware from the OpenPLI
wget http://downloads.pli-images.org/feeds/openpli-4/all/firmware-xc3028-v27_1.0-r0.3_all.ipk
opkg install firmware-xc3028-v27_1.0-r0.3_all.ipk
Thanks !
So I try to make my second VU working with another DVB T USB (Siano Rio Digital Receiver) . I had the same king of error message and I downloaded the missing file
https://linuxtv.org/downloads/firmware/isdbt_rio.inp
and put it in the /lib/firmware directory. I have no error message in the Debug anymore, but not able to display any channel and not it do not find any chnnal either
could you have a look at the debug file if I missed something ? Thanks
I'll investigate with my Siano device ....
