No channels found
valdemirs
Hi,
My Vu+Duo² arrived in my home.
I did network config -> ok, but I can´t find channels with my DVB-C tunner (I only use cable).
Hi nunigaia,
Yes, I speak Portuguese...
Thanks a lot.
Do you know the frequencies for Brazil? ... i think for America ... you have to check all flags ... that are <no> for <yes > .... but, post your cable frequencies or tell me, what are yours cable provider, so i can probably check the frequencies!
I have another STB in my home (working fine), and this is the data that I found in it:
Frequency Start: 111MHZ
Frequency End: 802MHZ
Symbol Rate: 5217
256QAM
My Provider is Net Serviços de Internet
Symbol Rate: 5217
256QAM
Ok ... if you have that ... by remote control, on the last parameters of tunner configuration, check QAM 256 ... and by hand ( remote control ), where symbol rate is 0000 ---> 5217.
<save> the configuration and,
Make a search of channels... and reply!
Symbol Rate: 5217
256QAM
Additional information
In your particulary case ...
Symbol Rate: 5217 -> Modulation Mode -> 256QAM
FREQUENCIES:
243.000 399.000 537.000 183.000 417.000
525.000 543.000 549.000 519.000 291.000
111.000 117.000 123.000 513.000 507.000
435.000 405.000 411.000 441.000 447.000
255.000 261.000 297.000 555.000 309.000
315.000 321.000 327.000 327.000 381.000
387.000 393.000 315.000 237.000 207.000
279.000 285.000 267.000 273.000 561.000
423.000
Best regards,
Note: I think that you have told that, you live in S.Paulo.
Hi Nunigaia,
Thanks a lot for your help .
I did that changes that you told me, and now I´m able to scan all channels from my Cable provider.
Now, I´m looking for any tool to connect to my Vu box and transfer files, see configuration, etc.
Have you networked your Duo 2, via a router? If so you can use the VU+ Control Centre, which includes Filezilla, a FTP program, as well as Webif, and other tools, to allow you to interact with your VU+ from a PC, or other device.
