No confirmation on Backup menus and OK key behaviour
AlexWilMac
Moderator
To OBH coders.
I noticed two behaviours in the Backup menus, one of whom is surely new, and which I believe are not comfortable.
They occur in both submenus: FullBackup and Personal backup.
1) When you press RED to delete a backup there is no longer the warning, confirmation message: so, pressing RED immediately deletes the file, and this is dangerous (because there is no trash chance, in this case).
2) Pressing OK corresponds to pressing GREEN and it leads to the same confirmation message you have with green. It happened I restore by mistake a full backup just because I had pressed twice OK before entering the submenu (believing I hadn't pressed this key properly the first time).
Backup is a delicate function and I think the coloured buttons are more appropriate than OK to launch these functions.
I suppose this comes from "cousin" image ViX but this seems to me incoherent to the fact they changed the SCAN procedure, where you now have to press GREEN instead of OK and here is exactly the other way round! ;)
