No current EPG in channel list
Eddie12345
I have problem with EPG in channel list and infobar. Show only next but not the current.
2nd problem: Epg in chanell list is ok in czech but after zap is replaced with norwegian or english version from TP (Animal Planet HD, Discovery HD, History Channel HD, etc)
sat pos:0.8w
provider :UPC Direct (currently FREESAT)
box: SOLO2
image: BH last 3 images (I have VU only few months)
problem appears only on chanells with Czech and Slovak EPG
EPG DATA is from sat NOT from crossEPG or other source
tested with 3 or 4 skins (problem is same), E2 language is set to CZECH
in normal EPG is data OK
screenshots first bug
2nd problem screenshot
Press blue button, then red button and then red button again, then disable the option Enable EIT now/next in Inforbar.
Press Red to save, and then exit and restart E2.
solution disable the option Enable EIT now/next in Inforbar is NOT WORKING. EPG on the right "blue current" not show
replacing with nor/english EPG on shared channels after zap is still there
when disable EIT at all then on some channels EPG is missing.
Sorry I thought you meant it was only not showing on the infobar.
Ok disable it for the channel list also
when disable EIT at all then on some channels EPG is missing and never appear
blue current on the right in and extended infobar not showing epg
please look at screenshots
disabling EIT make it only worse
I have exactly the same problem when using UPC EPG (from SAT transponder). In NOW-NEXT Infobar everything is fine, but in the channel list the NOW description is always missing. It only occurs when using EPG from the transponder, it shows correctly with Rytec EPG.dat downloaded. Hovever, rytec EPG is missing a lot of channels for UPC, so I would like to stick with the EPG downloaded from the transponder. I guess it might be some bug with the EPG grabber?
