No internet connection
koolkind
Hi I was watching chelsea match suddenly the vu+ solo2 loose internet connection it was wired, I checked the cable using laptop and there is connection. Tried a few different setting like disable/enable DHCP. but this morning was working OK.
Any idea why? I noticed it does happen during weekend only.
Thank you
Thank you
Can you connect to your box via Telnet/SSH? Can you check from console connection (telnet/ssh) from box if Internet works (ping-ing some hostnames like www.google.com) ?
