No LAN connaction
peja72
Im useing bh 2.1.6 lan wierd connaction dont work i try different cables start up rauter nothing try direct with out rauter and Box get IP use DHCP yes
Probably you have some problem with LAN setup.
Maybe there is a wrong gateway setting...
How have you setted the LAN on your Duo2?
