no new plugin found problem
kamranlpr
hi
i have vu+ultimo 4k when i go plugin menu there is a massage "no new plugin found" i do network test and evrything seems ok please help me to solve the problem.
tnx
That's very little help.
Perhaps you should try a non-experimental image and see if you can access the plugins downloader.
In Bh and OBH image you have feed and plugins/skins/setting to download.
Five from him is installed on image from begined
i have install the BH but i have still problem to download plugin and addons
for addons , "sorry,connection failed"
for plugin"done- installed, upgrade or remove 0 package with 0 errors
please help
You no block any conection on your router ?
You try how work feed on other image, maybe your image damaged and now is no conection
What are you trying to install?
Which plugin ??
As I see you trying to install plugins with software management ?
These plugins are intended for installations in the original image
From VU + image original.
Some of these plugins are old and do not work anymore.
Some have lost competitiveness and can not be installed.
Some can be installed.
Some will not work with BH and OBH image.
For a Black Hole and Open Black Hole image, look at the plugins here.
Green Button >>yellow button>>Addons Download Manager>>Black Hole Plugins
and
Green Button >>yellow button>>Addons Download Manager>>Black Hole Feeds Plugins
If you do not have contact with these plugins servers
Then check your network configuration
Which plugin ??
and
Doesnt work i think its for our internet some website are blocked by goverment here such as this site i see this page by vpn do you have any idea to solve the problem ?
