Sorry for late answer and thanks for yours, I have give up this picon stuff it just want work.
Picons work perfect in Flash and all other images in multiboot just not BlackHole and i use only skin_default ao no modded skins only original skin that comes with the image
I try clean image from scratch not workin, then i try backup of my image in the flash since that one works but no luck.
Has Multiboot installed on usbstick and as i wrote in my first post, only diffrence is that Multiboot Image dont show /media/usb in device manager instead /omb but when open thats my usbstick with picon folder.
If i use FTP and open /media folder i can see both /omb and /usb
Have only picon folder at /media/usb/picon/ no other place not on hdd and as i describe picon works perfect in Flash Image (BlackHole) in multiboot OpenBlackHole 4.1 but not BlackHole in multiboot.
Installed for testing OpenVix OpenATV OpenPli and they all work with picon in multiboot
Installed for testing OpenVix OpenATV OpenPli and they all work with picon in multiboot View attachment 35023
I first downloaded picons from BlackHole addons and they installed on usb from my flashImage updated picons since the one for 0,8w is old and outdated. So in Flash everything works perfect
What i have not tested is to install them agin from BlackHole Addons manager but in multiboot image and then update the picons just as in my FlashImage.
Maybe there are some refernces in the install file that helps Multiboot image to find the picons
