Why put them on your HDD? They should work on LCD of duo2 off usb?Since I put my picons in the HDD directory (/media/hdd/picon/) they are visible on the LCD but not in the info bar. There is only BH sign visible in the info bar.
Before, I used to store them on USB device and there was no such a problem.
I don't want anymore any device to be connected to my receiver.Why put them on your HDD?
Sorry, but I don't know what you are about in this sentence.They should work on LCD of duo2 off usb?
Yer I'd try deleting them m8 and then install again.No, I haven't. Do you think that may help? I will try.
I'm not using a standard skin, I'm using "ArmyNexGenGradientHD"
But this is not an original directory for picons, isn't?@jwlalek : /usr/share/enigma2/picon/ is mine flash folder for skin (TV infobar) picons.
Where do you keep your picons, HDD or USB?Hi, @jwlalek . I use the ArmyNexGenGradientHD skin and the default BH skin. There is no problem to display the picon in info-bar and LCD for both of the skins. Check the picon path.
