NO R/W on Samsung 850EVO 250Gb on Ultimo4K
Hi
I have upgrated my VU+ Ultimo to an Ultimo4K, but I have not been able to use my Samsung 850EVO 250Gb in the new Ultimo4K.
I use BlackHole-3.0.4-vuultimo4k Upgrated to "E", but I make to work with the SSD.
Is there a driver missing for the SSD i 3.0.4 / ultimo4K?
As far as I know, it does not need any special driver.
Did you initialize it, mount it
whether it is seen in the BH device manager ????
I do not have SSD in box but in principle have to work like every other disk.
Are you sure it's well connected?
If you have a chance you might try to first format it on a PC
An SSD is nothing different from a HDD. So, if you don't see it listed, it means it's damaged or you did not connect it properly.
After you see it listed (menu INFO / devices) and you have initialised it, you need to map it as /media/hdd.
And, yes, format it under a PC if you can, by a Linux LiveCD as ExtFs4
It did work properly in my old ultimo.
I have now had mounted on my PC made a format, mounted on a Raspberry Pi 3 and formated in Extfs4.
I will try in the upcoming weekend to mount it in my ultimo4k.
I have an backup af my running 3.0.4.E on another SSD 128Gb as a fallback
Update:
My ATA(LITEON IT LCS-12) did the same, so I recon that it was the skin (not default) that made the error. I have now reinstalled with default skin, and have no errors.
