no rewinding possible yet ...
cerval2009
Hi to all and sry for my bad english. First a " huge ty " to Blackhole team !! In my Vu solo original receiver i use this image in flash : Black hole 2.0.2 rev. D meoboot. Also i use the same image in my usb stick 2G with meoboot and my receiver work really Perfect. The only problem that i ve is : When i watch I.P T.V i can't make zapping to the channels with left + right buttons in the remote control and i read this message : no rewinding possible yet !! I put another image for test in my usb stick and the zaping in I.P T.V with left + right button's work excellent !! The truth is that i love to use black hole images and i don't want to change this. ( i watch I.P tv direct from the bouguet's list ** not with a plugin ** ). Any help pls ???????????????
Are you using into BH imaeg some plugins like Permanent Timeshift?
Try first with a clean BH instalaltion, secondly post details about DVB service you are using and we can try directly with our boxes.
Hi again , the only plugin that i use is the ******* plugin and the clean memory 108. Of course first i try with a clean BH instalation but the same situation. Here is the detail's that you want from my dvb service ( #SERVICE 4097:0:1:0:0:0:0:0:0:0:http%3a//3user%3apass@ipadress%3aport/1.ch: Really ty for your time !!!!
try to press arrow left or right for about 2 sec.
I've tested it on solo2 and it works - you can use arrow left/right next to OK button or both arrows next to 0 (zero) button. In both cases I'm able to switch channels over
Hi again mate. maybe you don't read carefull what i write. The problem is that don't work the left/right next to OK button. ( i tried 3 other images and work perfect ) .
You have tried images based on Pli not on Vu+ git.
If you like another image use it.
bye
bye
if i liked Pli images like you write Mr Shiro , i will not be here now , but bec i m fun of black hole for this i report my problem to can find a solution.
The Pli code is now deeply different than based Vu+. If you like the Pli features you have to swich to a Pli based image.
I've written above what works for me - when I press left or right arrows next to OK button for about 2 seconds (maybe a bit shorter than this) I can zap to another channel/stream. If stream I'm watching is first on my iptv channel list when I press left arrow next to OK button I'm getting last dvb channel on my list. You got it?
If I just touch the arrows it gives same info like you got: 'not rewind possible yet'.
I used IPTV list updater ver 1.0 to add streams to my channel list.
Hi! After 4 years do you have any suggestions?
Have clear BH 3.0.2 on Solo2.
Same "No rewinding possible yet" when switching between IPTV channels.
