Hi guys - Just bought my first ever receiver and satellite and having a few issues getting things up and running. In terms of kit I have; Vu+ Duo2 (latest black hole), Primesat 85cm transparent dish, 2x Primesat platinum quad LNBs and 2x 4 way disecq switches. Before I mounted the dish on the wall I just wanted to test by putting the dish in the garden and running an 11m cable from the box in the house, into a satellite meter and then connected the meter to a single LNB to pick up Astra 2 only. I pointed the dish in the correct direction by using the Dish Align app on my iPhone and turned on the satellite meter, but absolutely nothing happens, not a peep out of it and the needle doesn't move. I've moved the dish around including raising it high but still nothing, I tried the other LNB just in case but that didn't work. I eventually bought a pre-made short cable (I made the 11m myself) and brought the dish indoors just to see if there would be a response on the meter, again nothing. I also performed an auto scan whilst the dish was outside. What am I doing wrong? Surely it's something stupid? I have triple checked that I'm plugging the correct ends into the meter. Should the meter needle move as soon as you plug something in or do you only hear/see something if there is a signal? Any help would be much appreciated.
