no signal ?
Grizz
Hello,
Any ideas to this slight problem?
Vu+Uno
Bh 1.6.4 image
Cyrus E2 settings (2 weeks old)
Sat 1W (Telnor)
went to Discovery Science channel watched the programme for about 20 Min np,
moved on to Discovery (N) (same Sat) and watched that for a while then moved onto History Channel, after a while I went back to Discovery Science, this came up with no signal !!!!! went to Discovery (N) all OK!!! strange,
looked at the settings :-
Discovery Science 11862 H
Discovery (N) 11229 H
Checked Lyn-sat, all correct, checked the XML file, all correct. So, I thought I'll rig up the DB7020
and check the Discovery Science Freq, this showed 11868 (6 out), back to the Uno, did a manual scan with the info from the DB7020 and “wow” all worked including 12 other channels that I couldn't get( was saying no signal.)
Now is this a tuner fault or machine fault (still under guarantee) or is it a bug (I'm running BH 1.6.4)
This makes me wonder what else I'm missing (saying no signal)............
Any idea's ?
TTfn
G
